302 ID...
302 ID...
...need help to figure out what this thing is sittin' in my garage!!!
i found some numbers cast in the block above the starter area:
EOAE
D3C
DOESN'T MEAN SQUAT TO ME!!
On the rear top-side of the intake along one of the runners there is a number cast in to it, (intake might be aluminum?): RF-E3ZE-9425-FC
There is a Holley 4-BBL bolted to the intake also...Double roller timing chain and 2-bolt mains...
As far as I know...this motor is STOCK & was running when pulled.
PLEASE HELP!!!...what is it?????
EOAE
D3C
RE: 302 ID...
could be a motor out of a 83 mustang...I assume that it's a 302 if the intake is aluminum and has a ford logo on it then it's most likely a 83-85 h.o 4 barrel intake = nothing special as is the motor itself[&:]
RE: 302 ID...
Thanks...alot of "stuff" in the way...couldn't see the left side of the motor.....I'm gonna
wheel it out in the light & get a better look at it & see if I can find anything else...maybe pull a valve cover & see whats under there & look for some numbers...
RE: 302 ID...
ORIGINAL: rockher_man
If this one on the stand turns out to nuthin' special...I still got the 1972 F-Series truck motor that came with '56 F100 we just picked before Christmas...
RE: 302 ID...
mjr46...hey man...THANKS...at least I know what I'd be starting with! Still haven't had time to pull the stand out & turn itaround to get a look at the left side. Seem the only parts missing are the starter & oil pan.
Now I need to get some numbers of the 302 in the '56 F100 & see exactly what that is ...I dude we bought it from said the 302& C4 came from a 1972 F-series pickupdonor...
I be back when I climb under that little sucker to try & find some numbers...I want to say THANKS EVERYONE!!!
RE: 302 ID...
tinman...thats what I was thinkin'...The '83 doesn't seen to be anything "real" special anyway...maybe I can use "some" parts ( carb, intake, or whatever...) off it or just get rid of quick for cash to use on the '56...
I gotta get under the '56 & get some numbers off the block to see what I'm starting with...pervious owner if kindafuzzy on some stuff...
The C4 will be good enough for this ride with a kit installed...I think....
I'd kinda like to build something like THIS: http://www.fordmuscle.com/archives/1999/10/400horse/
Galactic
04-29-2019 02:56 PM
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
