does this track time sound reasonable?
Old 01-13-2008, 08:14 PM
90mustangkid
90mustangkid's Avatar
Default does this track time sound reasonable?
i just built my first motor with my dad and im goin to taking it to the track hopfully this friday but i wanted to see what u guys thought about it first..
its the stock 302 block bored .30 over
has a 600 cfm holly carb
edelbrockperformer rpm air gap
speed pro cam .472/.496 (hydrolic) as well as the lifters
speed pro flat top pistons with molly rings
cleaned stock heads
bbk short headers with no cads with flowmaster super 40's 2.5 in all the way
HCI distributer with 8mm ign. wires and ngk plugs
as far as the drive train stock t-5 with 5.0 pro short shifter
stock drive shaft
3.77 gears and upgraded clutches
we also switched aroundclutches were in a different order to make both tires lock alot easier
ill also be running et slicks on the back
and had full race suspension in the back
i think the car wieghs about 3250 with me in it
my estimate was a 13.2 in the 1/4... are my hopes up to high or does that sound like it could happen
90mustangkid is offline
Old 01-13-2008, 08:19 PM
nitrous_bob
nitrous_bob's Avatar
Default RE: does this track time sound reasonable?
no that sounds a bit hi
13.50-13.60 is prob right on the money
is it a hatchback ?
w/ a full slick you might get closer on a 5k launch , but i still don't better than a 13.40
but even w/ that.......be happy w/ it, and go from there, you built a motor w/ your pops and you guys will have a blast
nitrous_bob is offline
Old 01-13-2008, 08:22 PM
90mustangkid
no its a fox body and the wieght is an est from what ive seen online
Old 01-13-2008, 09:26 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I have a similar set up in my 92 but with a performer intake and ported stock heads and a f-cam and 3.45 gears and with slicks the best I've pulled in it was 13.69@99..the stock heads are what's gonna hold you back......
mjr46 is offline
Old 01-13-2008, 09:56 PM
90mustangkid
if i were to put some ok set of trickflow heads on.. what kind of difference would it make to my car in hp and 1/4 mile time?
Old 01-13-2008, 10:18 PM
mjr46
mjr46's Avatar
probably get into some low 13's then^^^^^
mjr46 is offline
Old 01-13-2008, 10:38 PM
67mustang302
67mustang302's Avatar
Good heads and you can get low 13's on street rubber. Check out my sig, a 3.00 gear but h/c/i + supporting mods. It wasn't quite tuned right and was having suspension issues so it couldn't launch for jack. And that was with a 3.00 gear on worn street tires at 40psi.
67mustang302 is offline
drfister
05-03-2018 10:38 PM
spectreman
03-31-2016 09:26 PM
squishbang
12-04-2015 02:29 PM
GimpyHSHS
08-29-2015 06:30 PM
ccwebb
08-11-2015 06:47 PM
Quick Reply: does this track time sound reasonable?
