Timing Chain and Roller rockers
RE: Timing Chain and Roller rockers
Lift is not a factor with piston to valve clearance.
The higher ratio does increase the rate at which the valve accelerates off the seat and closes, but peak lift is not an issue.
What happens if i use this cam with 1.6 roller rockers, I got some Crane Energizer 1.6 roller rockers. Will this fit good without a problem or it wont have enough clearance for valve covers.
mungodrums
10-07-2015 04:01 AM
Golfsito
10-06-2015 11:02 AM
09-08-2015 11:50 AM
