79' oil pan in a 92' Fox?
Hey does a oil pan from a 79' mustang/capri fit in a 92' fox? I am swapping a 73' 302 into my 92 LX and of course it has no hole in the block for a oil dipstick, so I need a pan with the dipstick hole in it. Thus a 79' oil pan, or pay an arm and a leg for the aftermarket kit.
RE: 79' oil pan in a 92' Fox?
ORIGINAL: dimebag
hm... pic of the pan?
as for the dipstick... didnt some come with them in the timing chain cover? you could make something work
older 302's use a front sump and the dipstick is in the front of the motor through the timing cover. Fox's use a double sump with the larger to the rear of the motor and the dipstick going through the right side of the lower part of the block. Some older fox's had an oil pan that the dipstick went in through the side of the larger sump.
