Rocker Arm Q
Rocker Arm Q
iv had a set of ford racing 1.6 rockers laying around ever since i bought the car (they came with). I never installed them becuase i think the install is out of my range but i recently found a place that i would trust to do it. My question is would it be benificial to me to install them on stock heads? If so would i want to upgrade my springs or anything eleswhen i getthe rockers done? I do not plan on swapping out my heads any time soon however the intake manifold and cam will be.
edit: they are not 1.6, they are crane cam 1.7 from ford for the cobra.
RE: Rocker Arm Q
Your stock rockers are 1.6, so I don't even think you will gain anything noticlble with the swap, maybe 2 or 3 RWH....I would save your money and wait to swap them when you are having more done, like heads and cam. Rockers are basically a supporting mod, they do very little on their own unless you change ratios.
RE: Rocker Arm Q
ok well my whole theroy with the car right now is every little bit helps, so even if it only helps a little bit, ill do it, after all its free hp becuse i already have them.
RE: Rocker Arm Q
I have those same ones on my car, put them on, but do it yourself. They are a direct bolt in....easy.
Read these directions
http://www.fordracingparts.com/downl...M-6564-All.pdf
RE: Rocker Arm Q
ORIGINAL: 5.0stanger
