Clearance issues with aftermarket hood.
To those that have a Harwood 3" cowl Cobra R style hood, did you have any clearance issues with the hood hitting your intake manifold? I have a Cobra GT40 intake and I have a 1" space in between the upper and lower intake manifolds. I had to put the spacer in so my throttle body would clear the valve covers. It seems like the back part of the hood is hitting the back part of the intake. Anyone have this issue?
RE: Clearance issues with aftermarket hood.
Here are some pictures of where it is hitting. The way the hood is designed, it almost makes it pointless to even have the damn cowl. Are all of them like this?
Arrow shows where it is hitting on both the hood and the intake.
Circle shows where on the intake.
That's the thing, that is just the first spot it is hitting. It is keeping the front of the hood from closing. Even if I sanded down the nub, it would still hit the rest of the intake. It seems as though the hood is more cosmetic then functional.
ORIGINAL: r.barn
Get rid of the SN95 TB elbow.
Install Fox style TB
and run 1/2" spacer instead
Fab up new CAI
Problem solved
Fab up new CAI
Problem solved
