need help choosing cam and heads for bbk intake
Gentlemen:
I have a BBK SSI upper and lower intake w/ 24# injectors, adj fp reg, 75 mm throttle body, 75 mm maf, pulleys, headers, h pipe, 3.73 gears.
I made the mistake of putting the intake on before heads and cam and now I need to go back and upgrade the reast of the top end. Do y'all have any recomendations for a head and cam for the BBK intake?
Thanks
Thanks
RE: need help choosing cam and heads for bbk intake
It all depends on how much your looking to spend, gt 40's and a e cam are nice and you'll get power out of them, but if you got the money i would go with alluminum heads and a pretty radical cam!!!
The best camshaft is a custom camshaft. It can be as tame or radical as you want it.
Ed Curtis @ www.flowtechinduction.com sells both, the AFRs and the custom camshafts, and everything in between.
Thanks for all of the help. I called BBK and the tech guy said that the wholeheartedly recommended the afr 165s and a crane cam w/ hydraulic rollers.
That is probably the direction I am going to go.
Thanks
Thanks
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
