24lb Injectors without calibrated mass air sensor?
Im doing my h/c/i at this moment and i have my 24lb injectors but to have mass air sensor, can i use them for now and in 2 weeks or so just intall the mass air sensor?
RE: 24lb Injectors without calibrated mass air sensor?
just keep the 19s on there until you get the proper MAF. 19s can hold up with an HCI swap. Just bump the fuel pressure. When you get the 24lb maf, just put the 24s on. Its easy. Just drain the fuel lines, unbolt the rails, and start swapping
TfcCDR
09-14-2015 12:08 PM
