The Build Is Finnished... Hello P600b
So I know this post is a little late, I ran into some issues with rubber tubing that caused my car to run like ****, but its back up and running well. There are still a few things I need to do to get it running outright (pcv issues, some replacement lines, boost gauge issues). But all in all the install went very smooth, aside from procharger failing to mention that a 3/8” npt tap is impossible to find, and the blisters i have from installing the oil lines.
Here are some pictures of the install, also there are two videos at the end, the first is of me firing it up, second is after we fully finished the install.
And Videos
http://s76.photobucket.com/albums/j1...nningP600b.flv
http://s76.photobucket.com/albums/j1...angStartup.flv
And Videos
RE: The Build Is Finnished... Hello P600b
I hope he's better than the guy that works/ed there name Bill. Was there twice and wasn't impressed. Swore up and down I needed a DFI set up. Took it somewhere else and they spotted the problem right away. You may wanna check out JJ at Woodbine Motorsports. He did mine. Very happy w/ what he did.
http://www.woodbinemotorsports.com/index2.htm
