88stang
RE: 88stang
my bad man i had my nubers confused i was looking at cams for my dads 88 that has been converted , i slipped you sre right it is 114 and not 112 . and far as getting the power to the ground you will need some suspension work though . let's let the cam thing slide this time dimebag to many buddies with different engines i got my numbers all jumbled [sm=imsorry.gif]
RE: 88stang
ORIGINAL: kweb288
It wont give you 360 at the wheels on a stock engine (its less, at the rear wheels he usually make 10-15 under 300), also why go with such a small shot of nitrouse? almost seems pointless......As long as the tune is GREAT, there is no reason it cant hold a 200 (would definatly stay closer to the 100-175 range though) also with that kind of power, if the car is stock your going to have a hell of a time getting that power to the ground, suspension should be one of the first things you do, along with tires
ORIGINAL: lxman1
Well, I would just get the TrickFlow kit with heads, cam, intake, pushrods and roller rockers. This will give you about 360hp to the flywheel. Use a C&L 73mm MAF and a 70mm Throttlebody. With the 75HP NOS, it should be around 375 or so to the rear wheels on the spray. Is it a 5-speed or auto trans?
RE: 88stang
a 150 shot would be safe , and yes you will get more power by shaveing heads as it increases the compression ratio , but what he is trying to say is you are purchaseing a set of heads that have way better flow than stock so you will get your power from there . what are you wanting to build an bracket racer all out drag car or a street beast ? and what rear gear are you going to run ? i am going to run 3.73 in mine cause in a 5 spd a 4.10 gear will make your first gear in your trans useless, it would be like a granny gear in an old hd stick shift truck, there for pulling but no good for anything else.
RE: 88stang
ORIGINAL: lxman1
288hp + 60hp NOS = 348hp to the rear wheels. That's pretty close to 350hp Figuring a 20% loss from flywheel to wheels. 375 was a bit high on my original calculation
ORIGINAL: kweb288
ORIGINAL: lxman1
the way you have it writen though, your saying that, or it seems that you are saying that the TF top end will net you 375 hp, + adding a 75 or so shot to things to bring it up more........
RE: 88stang
i have a 5 speed and probly gonna go with 373 gears. i pretty much wanna have a bad *** car for weekends but dont wanna change pistons. i wanna do what i can to the suspension and have a powerful top end. im gonna keep it speed density. i wasnt sure on the nitros but a 150 shot sounds great. and i know im getting new heads i was asking in shaving them would help me more or if i should leave alone
RE: 88stang
i would leave them alone for now . you go and put all those parts on you are going to see a big difference ( more like huge ).all that you are talking about putting on the car you will have plenty of horse for a weekend worrior.buy putting all those hipo parts on you will have to do suspesion upgrades or it won't hook for you , it will get squirlly and it will flex , and more than likely get you and or some one else hurt in the process . invest in some boxed upper and lower control arms , weld in frame ties , good shock and struts , good springs , strut tower brace wouldn't hurt .
