need info
Old 01-27-2008, 08:55 PM
mustang freak
mustang freak's Avatar
Default need info
i have a 1986 mustang 5.0,and i want to make it handle more tighter with out to stiff of a ride,and i wanted a much more powerful brake system with out spending 3000$ . what parts should i chose like to here some opines. thanks for reading
mustang freak is offline
Old 01-27-2008, 09:27 PM
stangbanger87
stangbanger87's Avatar
Default RE: need info
you could go with the front brakes for a 94-95 stang (bigger rotors and bigger calpers, but you would have to find some five lug wheels ) or refresh your breaking system . frame ties (weld in's) and a strut tower brace will stiffin it up but not so much that it rides rough ( i have that done to my 87 and it made it tighter but not to tight .) cross drilled rotor and bigger calipers are also available for our cars and they won't hurt your wallet to much
stangbanger87 is offline
Old 01-27-2008, 09:33 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
or you could jump up to the larger 11 inch rotor set up that 87-93 mustangs came with unlike 86 and below that have 10 inch rotors....all you need to do that is 87-93 spindles, rotors...I went with blind drilled/slotted ebc's and ebc pads and stock calipers and brake hoses..all this cost less than 375.00and it stops well!!!
mjr46 is offline
Old 01-27-2008, 09:45 PM
stangbanger87
hey man that is good info i might just put that to use on mine
Old 01-27-2008, 10:29 PM
mustang freak
what company should i look into for after market cross drilled roters and bigger calipers.cause that sounds like the best bet
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
RCS02v6
09-29-2015 01:46 PM
junior04
09-28-2015 10:53 AM
GLOCKer
09-28-2015 07:36 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: need info
