Why is the crank so hard to turn?
Old 01-27-2008, 02:55 PM
94gtcobra
94gtcobra's Avatar
Default Why is the crank so hard to turn?
Im trying to adjust the roller rockers but when i turn the crank with the ratchet is so hard to turn, and when it turns i hear air getting stuck inside the pistons, like the valves arent opening,but the valves are opening,is that normal? If I did something wrong what is it?
94gtcobra is offline
Old 01-27-2008, 03:51 PM
91hatchgt
91hatchgt's Avatar
Default RE: Why is the crank so hard to turn?
The reason it is so hard is because when you turn the crank, you are creating compression in the cylinders. That compression is what makes the crank hard to turn. I assume that you have the spark plugs out, and are finding TDC on each cylinder before adjusting the rockers???
91hatchgt is offline
Old 01-27-2008, 04:50 PM
67mustang302
67mustang302's Avatar
Yeah, it'll be 100x easier to turn with all the plugs out.
67mustang302 is offline
Old 01-27-2008, 06:23 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
What is the size of the tool you're trying to turn the motor over with? Yeah, if you're using a 10" ratchet as apposed to an 18" breaker bar, yeah I could see the problem.
Leverage, let it work for you.
PRO50SC is offline
Old 01-27-2008, 08:04 PM
dimebag
dimebag's Avatar
you dont need to find tdc to adj rockers...
i assume the plugs are NOT out... if so... take em out
dimebag is offline
Old 01-27-2008, 10:56 PM
Mustangkiler
Mustangkiler's Avatar
Definitly take the plugs out, on a side note i still never even got my balancer totally on, i tried holding the brake while car was in gear and having another person hold it with a pry bar with bolts in it, its almost there, any ideas cuz its about the only thing holding me back now.
Mustangkiler is offline
Old 01-28-2008, 03:50 AM
lxman1
lxman1's Avatar
Something is really wrong if your balancer is that hard to get on. Pull it back off and see what is getting scarredup!!
lxman1 is offline
Meystang
09-25-2015 04:05 PM
Wombatnation
09-13-2015 09:16 PM
TheDutchTexan
Mustang Videos
09-10-2015 06:51 PM
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
Quick Reply: Why is the crank so hard to turn?
