How much is this 87LX 5.0 worth?
ENGINE:[/b]
DSS RACING 306 MOTOR WITH 12,000 MILES,
1989 COMPUTER,
SCT CHIP (TUNED),
B303 CAM,
E7 HEADS PORTED AND POLISHED,
24 LB FUEL INJECTORS,
TAYLOR SPIRO PRO 8mm PLUGWIRES,
MSD DESTRIBUTOR CAP & ROTOR,
CRANE CAMS PS91 PERFORMANCE IGNTION COIL,
TRICKFLOW UPPER AND LOWER INTAKE,
BBK 70mm THROTTLE BODY,
BBK COLD AIR KIT,
75mm MASS AIR SENSOR CALIBRATED,
24LBS INJECTORS,
LIQUID INLINE FUEL PRESSURE GUAGE,
ADJUSTABLE FUEL PRESSURE REGULATOR,
HEADERS,
H-PIPE,
FLOWMASTERS,
B-4COOL RADIATOR,
MSD 6AL,
SMOG ELIMINATOR,
ADJUSTABLE CASTER CAMBER,
STRUT TOWER BRACE,
TRANSMISSION:[/b]
TREMEC 5 SPEED TRANSMISSION,
PRO-5 SHORT THROW SHIFTER,
KING COBRA RACING CLUTCH,
[/b]
REAR-END:[/b]
31 SPLINE HARDEND AXLES,
C-CLIP ELIMINATOR,
3:55 GEARS,
BALANCED ALUMINUM DRIVE SHAFT,
[/b]
SUSPENSION/BRAKES:[/b]
KYB FRONT/REAR SHOCKS,
UPPER AND LOWER CONTROLLER ARMS,
SUBFRAME CONNECTERS,
POLYURETHANE BUSHINGS,
TORQUE BOXES,
DRILLED/SLOTTED ROTORS,
[/b]
INTERIOR:[/b]
HOOKER PRO STEEL ROLLBAR,
BILLET TRIM,
BRAND NEW KENWOOD CD PLAYER,
BRAND NEW PRESTIGE ALARM WITH KEYLESS ENTRY,
NEW CARPET,
NEW HEADLINER,
SEATS ARE PERFECT,
ASHTRAY WORKS PERFECT,
[/b]
BODY/EXTERIOR:[/b]
COBRA R 17X9 WHEELS,
BRAND NEW 245-45-R17 MAXXIS MA-V1 RADIALS,
SALEEN WING WITH BRAKE LIGHT,
This car has 12,000 miles on the motor and tranny with 95,000 and counting on the body.The interior is very nice with new carpet and headliner. The seats are perfect. The paint on the car is good with minor blemishes. The body is very straight and has never been wrecked. The A/C works great. The cruise control does not work, the heater is bypassed(was so when I bought it), the passenger side lock motor does not work, the speedometer bounces above 40mph and the front left panel was hit by something. Panel on order and the other above mentioned issues are minor and easily fixed.
[IMG]local://upfiles/90041/DD3CFB1F835D4380A5B66A4DE1806BC4.jpg[/IMG]
1989 COMPUTER,
SCT CHIP (TUNED),
B303 CAM,
BBK COLD AIR KIT,
24LBS INJECTORS,
HEADERS,
H-PIPE,
FLOWMASTERS,
B-4COOL RADIATOR,
MSD 6AL,
SMOG ELIMINATOR,
STRUT TOWER BRACE,
TRANSMISSION:[/b]
[/b]
REAR-END:[/b]
C-CLIP ELIMINATOR,
3:55 GEARS,
[/b]
TORQUE BOXES,
[/b]
INTERIOR:[/b]
BILLET TRIM,
NEW CARPET,
NEW HEADLINER,
SEATS ARE PERFECT,
[/b]
BODY/EXTERIOR:[/b]
RE: How much is this 87LX 5.0 worth?
thats pretty nice, everythign is setup almost identically to mine. im in the process of paint tho. sadly these body styles dont go for too much. honestly if you parted the car out you get alot more from parts. dont let someone rip you off trying to used kelly blue book cost though, its worth alot more than that
I know KBB is WAY off. I have a guy offering 6500. Is that about right or do you think it is worth a little more? I just have alot invested.
Or should I put it this way. What would you sell or buy it for?
well for the economy the way it is thats not that bad. ive seen them go for more and ive seen them go for less. seems like you have a really nice setup there. thats probly a little lower than id take for the car but something like that is really up to you. it depends on what the car means to you and how bad you ar ewilling to loose your as$ on the deal? being such low miles and all the performance parts you have on that car i wouldnt give it away at that price
So I have one 6000-8000 and a 6800-7200? Lets put it this way, IF you were looking at the car( i know you would want to pay a little less than what it is worth) then 6500 is giving the buyer the better deal(for the most part)....
Thanks,
Chris
Thanks,
Chris
