Titanium spray paint for 2 tone Foxes
After pulling pin stripe, all paint underpin stripeis Titanium silver EXCEPT, theTwo 9 inch moldings on each side of door, these have Dark Grey paint under wherepin stripe was.Where can Iget some close matching Titanium paint and should I bother w/ sanding and priming since I will repaint in 1 year or so?
RE: Titanium spray paint for 2 tone Foxes
Any automotive paint shop can mix the color for you and put it in an aerosol can. If you're talking about the 1/4 panel trim behind the doors, it comes off of the car pretty easily. It would be about a 3 hour job to completely repaint them and probably cost about $20.
Otherwise you'll have to match something up off the duplicolor rack at Autozone.
I was planning on taping off the molding, exposing ONLY where the Pin Stripe was and painting there.Good idea to remove and paint with apaint matched by a paint shop..thanks.
ORIGINAL: camaroeater
After pulling pin stripe, all paint underpin stripeis Titanium silver EXCEPT, theTwo 9 inch molding on each side of door,
Anyhow, good luck. A good paint shop will fix ya up.
Sorry, i thought u did not understand what molding area i was talking about. I realize during edit that you are talking about the area of molding that is on each side of the door by tires (1/4 moldings).
