Whos running O/R midpipe w Smog delete
Besides swaping in a catted midpipe to pass emissions, I will alsohave toput smog pump back on. After I delete smog pump, how can I plug everthing so I wil be able to throw smog back on for emissions.Getting aO/R H real soon.
RE: Whos running O/R midpipe w Smog delete
i have an o/r x with smog delete...previous owner did it all..the smog stays out, i just got a stock h that had the smog tube closed up, and i put that an for inspections..
ORIGINAL: camaroeater
I won't pass emissions w/o a smog pump.
ORIGINAL: Albizo66
where you from? i passed NJ emissions without a smog pump...and jersey is pretty damn tight
if you are 100% certain that you need the smog to pass emissions, than idk if i would delete..i dont think it would be too much fun to have throw all that sh*t back on every 2 years or w/e it is..
idk man, i got through jersey emissions without one, and we are like 2nd to cali...i failed the first time, for NOX (only by a couple hundred) then the shop cleaned out my EGR system, and retarted the timing a little bit, and i passed by like 6xx...all with just a stock H, no smog..
Maybe I don't need smog pump to pass. I called someone here in az about a Usedmidpipe w cats and I remember him saying he only used it for emissions and that he did not hook anything up from smog pump to midpipe.
