how do you relocate a battery?
got the kit im gunan run the wires from inside the car. is this hard anything i should know. im going to do this when i have the carpet out of the car. and the back seats out also. this seems fairly simple then some parts seem hard.
RE: how do you relocate a battery?
so its cool to run the wire inside. where do i run the wires to and from and the ground also. thanks for all the help. i will have all interior out so it should be nice and easy to run wires.
Here's a link on how to wire it w/ a cut off switch. It not to difficult.
http://forums.stangnet.com/showthrea...715170#7050390
If you are going to run it at a track that does tech inspections then you are going to need a cut-off switch that actually cuts the car off. More times than not you are going to needa relay to kill the alternator to cut the car off when you throw the switch.
If you were going to run inside the car, do it along the driveshaft hump or along where the floor meets the sides(so its out of the way) if youre planning on recarpeting. If youre making it a trackcar, then whatever. Personally Im a fan of outside the car, tucking it up with the fuel and brake lines.
logan409
09-26-2015 07:43 PM
