87 5.0 5 speed good deal or not?
Old 02-11-2008, 09:18 PM
pimpinstang1
pimpinstang1's Avatar
Default 87 5.0 5 speed good deal or not?
a friend of mine is selling a 5.0 5 speed 87 mustang gt all it needs is clutch line adjustment, rack and pinion bolt tightened and fuel pump. 600 bucks should i get it??? he said he kept up with 5.0 cobras. im thinking about getting it and dropping an e303 cam with more mods what mods should i get to get this whip in the 13's?
pimpinstang1 is offline
Old 02-11-2008, 09:23 PM
stang8689
stang8689's Avatar
Default RE: 87 5.0 5 speed good deal or not?
Buy it ASAP, 600 bucks for a running 5.0 and non-grinding T-5 is worth atleast that. Get some heads for it, thats the weakest point
stang8689 is offline
Old 02-11-2008, 09:36 PM
bighungrymatt
bighungrymatt's Avatar
for $600 I would buy it
bighungrymatt is offline
Old 02-11-2008, 09:59 PM
pimpinstang1
sweet i was looking to drop in an x303 cam is it worth it??? what drop in mods do you guys suggest?????
Old 02-12-2008, 04:32 PM
pimpinstang1
guys the owner of the car knocked down the stang to 400 bucks im pickin it up this friday
Old 02-12-2008, 05:19 PM
x1n54n3x
x1n54n3x's Avatar
where do these deals come from?? when am i gonna get my crazy good deal??
x1n54n3x is offline
Old 02-12-2008, 05:28 PM
stangbanger87
stangbanger87's Avatar
i would pick it up in a heart beat . but you can not run an e303 in a sd car unless said sd car is converted to maf . check out the speed density section for ways to get that pony runnin in the 13's . you can not run any fms cams due to lobe seperation has to be at 114 degrees seperate, and most of those are either 112 or 110. if the car has been converted to mass air then by all means go with the x303 or e303 . far as heads i would look toward afr
stangbanger87 is offline
Old 02-12-2008, 08:07 PM
pimpinstang1
well its an old friend and how do i convert this beast into MAF????
Old 02-12-2008, 08:13 PM
stangbanger87
either pick up the fms conversion kit or go shopping around the bone yards for 89 and up 5.0's to get the ecu mass air meter and wireing from it to convert. i would keep it sd if it was me by i am privy to the sd injection .
Old 02-12-2008, 08:19 PM
pimpinstang1
so how do i get the mass air meter??? any pics?
Quick Reply: 87 5.0 5 speed good deal or not?
