What should I get?
What should I get?
Ok I'm figuring I'll have $1000 to spend of my tax return money! But I dont know what I should buy!!! I have a 87 5.0 with MAF conversion, fenderwell CAI, Fcam, gear drive, and everything else is stock on the motor! I alsohave 4.10 gears! So I dont know what I should buy! I'd like to get a decent set of heads but I cant find any! Any suggestion for some power adders? No NITROUS...... at least for now!
Thanks for any help
Joe
Thanks for any help
Joe
RE: What should I get?
ORIGINAL: 87lxBlackWidow
get yourself a gnarly intake... trickflow r series is pretty good and will run you about 600 w/ shipping, then go to blueoval and get a 75mm tb and egr spacer
ORIGINAL: FASTBLACK
Warning!!! Do not take above advice.
if you wanna get an intake manifold, look at the TrickFlow street heat, or track heat, or Edelbrocks, or Holleys...they are all good
check corral.net/forums they have GREAT classifieds over there, its where i bought my car from...you can get a good deal on used heads
Ok, I was lookin at the street heat intake from trick flow. Will I notice any gains? Or should I just save my $1000 til I get some more money and buy some AFR heads? If I save and buy heads, will my stock intake and injectors work ok with it?
http://corral.net/forums/showthread.php?t=993419
there ya go, edelbrock heads for $800
RPM 2 Upper and Lower for $350
so for $1150 (plus shipping) you can have heads, and new intake...
god i wish i had that money
to get the most out of new heads and cam, youll need a bigger t/b, bigger maf, and get a maf calibrated for, and upgrade to, 24# injectors
