new motor is up and runnin finally. idle clip
RE: new motor is up and runnin finally. idle clip
ORIGINAL: bighungrymatt
sounds good, congrats man
heres a few more pics of the final thing in
i am buying a new electric fan from the spped shop that helped me out said they would only charge me half of what the normal hour rate is and they do a really nice job with stuff. as they have a dyno so when i get a few miles on her i am going back down there
I'd be a little concerned about the amount of smoke coming out the tailpipes. All new engines smoke at first, but then it goes away after awhile... like after 1/2 hour or so of running it. I hope there isn't a problem with it. Sounds good though.
Looks awesome, sounds even better. I need to get some sound clips up of the 331. The choice of color on the block is different, but I like it a lot. Great job man. Now gets the bugs worked out and I want to see a tire roasting video
ORIGINAL: capri debris
yes all the smoke was from the motor it had just started so it was cold and it is cold here. no worries it does not smoke or anything when warm
ORIGINAL: 91hatchgt
i am having a problem gettin the ckutch adjusted right. a guy told me to move my firewall adjuster all the way in towards the firewall and then get underneath and tighten up the nut on the cable until it gets pressure on it and then lock then nut. and then go back and adjust the adjuster out until i get the pedal around the middle and what feels good? i am just gettin a lot of chatter and it engages towards the top i need to get it back down does this sound right as adjustment wise??
sorry guys i have been real busy you all want to know whats been done to it so here you go
88 xxx block main lined,decked ,bored .030,align honed and bored with torque plates,all the stuff
stock crank turned
stock rods shot peened,arp bolts installed,rods resized
probe forged flattops with heads roughly 9.3-.95 comp.
twisted wedges 2.02/1.6
trickflow stage 2 .542/.563 286/294 @.050 224/232
edelbrock rpm 2
PP 70 mm tb & spacer
30 lb injectors aeromotive fpr
bbk shorties,bbk h pipe,flows
msd ignition,coil,stock dizzy
egr,a/c, and all smog crap eliminated
pp sfi balancer
ram sfi billet flywheel
new rebuilt wc t-5
spec clutch
new poly motor & tranny mount
and all the little stuff is new oil pickup,oil pump,double roller,arp bolts everywhere.. and more just cant think right now
stock crank turned
edelbrock rpm 2
pp sfi balancer
new rebuilt wc t-5
spec clutch
so what do u think how many horsies do u think shes got in her?
now i am gonna rip out stock suspension and install upr u/l control arms,strange 10 ways,moroso trick springs in the rear . all i need to get for the rear now is sum drag radials
andto the1320 here she comes got to get past this crappy weather first[8D]
