AOD trasmission lines
I recently converted a 90' gt over from automatic, to five-speed. Now i am using the previous automatic system from the 90' in an 85' coupe. When i tryed to remove the tranny lines, i could'nt get them out, so i decided to cut them, and get em out of the way. Does anyone know if the transmission lines will work on my 90' AOD from a 94'-98' ?
RE: AOD trasmission lines
no!!! just rejoin the lines.....you can make double flare fittings with the tool and go to your local parts store and get the right ends and rejoin the lines..I've done that many times with excellent results and no leaks
^^^ as long as they have the right bends and fittings.....why not go down to your local parts store and pick up some steel tubing and fab your own up..it's easy and quick
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
