novie 2000 kit
RE: novie 2000 kit
ORIGINAL: r.barn
same hp for same hp, a forced induction engine needs bigger injectors than an N/A engine.
36's would probably get you by, but you might as well get 42's while you're spending the money.
ORIGINAL: kweb288
also 42 pound injectors are a little muc hfor only a s/c upgrade and a cam? i mean im pretty sure 24 or 32 pounders would be fine for what im talking about
RE: novie 2000 kit
probably about 350ish......maybe.... Not really sure, that is what they advertise with the unit and stock pulleys but i will find out . Unless someone else has done it and can tell me
RE: novie 2000 kit
I got 36ers on a stock engine with a kb and it was way too much injector, but if your getting it dynotuned anyways get the bigger injectors instead of having to buy dif ones later, you can tune down any injector.
RE: novie 2000 kit
i did my motor first rebuilt 306 with goodies down below.wanted all the good stuff there for when i did a super/turbo.
if i had the chance to do it over i would definetely do the power adder first.
jwog666
12-27-2021 08:09 PM
