What gear do you do burnout in?
02-24-2008, 11:22 PM
just curious to see what gear everyone does their burnout in?
02-24-2008, 11:25 PM
RE: What gear do you do burnout in?
i think second gear is pretty much the staple gear.
02-24-2008, 11:27 PM
depends on what i feel like. if i want alot of smoke i rev it pop the clutch as soon as my car hits 5500 rpm i switch to second and hold
.. i haven done 3rd but im sure it will spin in 3rd... or if i want two long black lines i keep it in first and play with the throttle a little bit
...... man i havent done a burnout in a while... hmmm vid time mabe[8D]
02-24-2008, 11:28 PM
as far as at the track i assume?
02-24-2008, 11:30 PM
02-24-2008, 11:42 PM
yes for the track,
some people use first, some second, and some shift from 1st to 2nd...
02-24-2008, 11:48 PM
Really depends on your rearend gear ratio. I used 1st with the stock 2.73's, 2nd with 3.55's.
Quote:
ORIGINAL: bighungrymatt
yes for the track,
for straight easy burnouts.. just use 2nd. a line lock is ideal.. but not all that necessary
02-24-2008, 11:52 PM
thanks
I have 3.73s, was doing mine in first today, will do them in second next time. I also have a line lock
02-24-2008, 11:53 PM
1st here[:@]
