New Mods = New never b4 idle problems
Hello everyone, i had installed a cobra upper and lower intake with a smog pump eliminator pully kit,under drive pullies, custom chip all the mods were done at a speed shop
now the car when 1st started up when cold it dies and runs like crap for a couple of minutes and then it runs fine, they told me that i need a egr block off plate and that would solve the problem true??? or not???
they said that they turned off the egr in the tune???
any suggestions would be very helpful
thanks
thanks
RE: New Mods = New never b4 idle problems
Try resetting your computer maybe. Unhook the positive an and negative cables on the battery and leave them undone for about 5 minutes. Hook them back up and start the car and let it run for a miute or two. That may work.
well if they said they cut out the egr in the tune and now ur getting that purged into the system, it will act kinda funny. but the egr is only "on" when you are cruising, not while its idling or at WOT. so when does it run like crap?
EDIT: my bad over looked the fact that it only did it when it was cold....if it only does it when its cold, i highly doubt that its the egr
JDWalton
09-24-2015 08:47 PM
Calizic
08-28-2015 01:46 PM
