5.0 Problems. TONS of white smoke... HELP!
RE: 5.0 Problems. TONS of white smoke... HELP!
more than likely it is the head gasket ,if you have ran it hot i would definately check the heads for warps and cracks how long ago was the gaskets changed ?
+1 on the head gaskets if you keep runnin it that way ur askn for trouble did you go somewhere and get youir head work done if so take it back you may get lucky and get it fixed that way......when they did the headwork did they check to see if they are warped.......could be the root problem.... good luck and let us know what ya find out
you have a had head gasket but do to a repeat failure I'd have the heads cheaked for warpage and or the block deck surface and make sure there is not a crack in a head
breaking
10-02-2015 01:27 PM
treesloth
09-28-2015 07:03 AM
