Got my cam specs from FTI (Going to be BADASS)
Yeah Ed Curtis makes a badass cam, gives you what you want thats for damn sure! Here is a brief rundown of the cam, lemme know what you guys think!
Valve Adjustment: .000” .000” Lobe Lift: .378” .375” Gross Valve Lift 1.60 Ratio: .605” .600” Duration @ .050” Tappet Lift: 224* 230* Lobe Separation: 112* Recommended Intake Centerline: 108* Specs at 108 Degree Intake Centerline: Valve Timing at Open Close .050” Tappet Lift: Intake: 4* BTDC 40* ABDC Exhaust: 51* BBDC (-1*) ATDC Specs at 110 Degree Intake Centerline: Valve Timing at Open Close .050” Tappet Lift: Intake: 2* BTDC 42* ABDC Exhaust: 49* BBDC 1* ATDC
RPM RANGE 331-347 2500-6500 RPM
[/align]
[/align]
RE: Got my cam specs from FTI (Going to be BADASS)
that is gonna be a nice sounding/performing cam it looks like congrats....seeing all u guys with the customs i kind of wish i went that way.oh well next time
how long to you get your motor running?
ORIGINAL: jtmustang
COmpleted his Cam Build Sheet, which includes alot of the things you mentioned. And informed him that its a street car, not much track use at all and wanted to spin the engine to 6,500 RPM to make nice power. Should be huge up top cam is built for mid to upper power
junior04
09-28-2015 10:53 AM
