stupid a** problem wich is gonna cause me to destroy it
Ok today my idle started staying at 3000 rpm now it has a new tps egr and the silver thingy on the side of the throttle body i fixed the vacuum leak and now its even higher what the hell is the problem?
[IMG]local://upfiles/91381/A374D34EEFDA407D93F24A87AB600790.jpg[/IMG]
RE: stupid a** problem wich is gonna cause me to destroy it
If you just replaced those parts....you should reset your base idle:
http://www.muscularmustangs.com/iac.php
It is on part 3......if that don't work, try the rest of the article
Good Luck!
Good Luck!
**UPDATE**RE: stupid a** problem wich is gonna cause me to destroy it
Well i cleaned the part you guys told me to and it still reving at 2500 and wont come down ... Now i forgot to mention my brake boost had a bad vacuum leak so i disconnected it and pluged it and after about10 min of running it started this problem so i put it back on the brake boost and it still doing it what now
jaiidutch
09-14-2015 10:29 AM
