Door tag rear gear ratio code
I have an 89 lx originally equiped with a 302 if that matters. My code under AX is F, I've searched the web and I see no such code. Supposedly it should be one of these 3...E,M or Z. Im swapping gears anyways but id like to know whats theoretically already in there.
RE: Door tag rear gear ratio code
Just to double check, or if you think they've been replaced you can do a simple check.
Jack up the rear so the wheel are off the ground, mark a spot on the tire and the driveshaft. Spin the tire around 1 full turn and coun't how many times the driveshaft spins, if it happens to be a hair less thatn 3 1/2 turns, that would be your 3.45.
That is pretty odd though, I never knew they put that set in them. Learning something new all the time.
inyadreems
08-21-2015 09:10 AM
91StangOwner
08-20-2015 11:34 PM
