should i call BS?
should i call BS?
heres a conversation i had with a guy over myspace, what do u think?
well i have speed density lol but ya the setup on mustangforums was my old setup but i sold that stuff to a bud, now its been bored to a 306, i now have ported and polished e7's very similar to thumpers, about the biggest cam i can run with the speed density, .600 lift springs, roller rockers, ported intake, inch spacer, 70 mm throttle body, eliminated ac, double roller timing chain, and all arp hardware, 373 gears no more drag radials, need new ones, lower upper control arms lowering springs, subframe connectors, castercamber paltes, strutbrace bar, iuve tweak with the computer alittle, but imma bout to switch over to a mass air. in about a year i will be tearing everythng out and either doing a 400 horse 347
or a 500+ horse twin turbo setup with the 306 so
----------------- Original Message -----------------
Date: Mar 18, 2008 7:48 PM
i was just curious what your mods are and how your running 300 hp?
RE: should i call BS?
I would think it's more in the ballpark of250 rwhp. Hard to tell with the "biggest SD cam" B.S.And I will be willing to bet his home ported heads are nothing like Thumpers.
Maybe I'm too oldto understand, but why would you even talk about cars on "myspace". I would think this is thekind of crap you would see on a normal basis.
it is b/s .512 is about the limit on stock sd .70mm is hard to run with stock sd . with 40p heads .512 lift cam and 40p intake the car would push around 298 at the crank ,transfer loss will put it at 280 at the wheel unless he is useing 100 shot , (which it is not listed ) he would hit a little over 300hp , i know the e7's can be worked to get good flow but being compared to a thumper no way . the guy ain't got a clue .
ORIGINAL: bighungrymatt
he probably does have that stuff done, just no clue what kinda numbers he is pushing
A lot of people do an H/C/I and with all the advertising of 300HP+, they think with a few more bolt-ons (headers, pulleys) that they are in the 400HP range...
Sad thing is, they are no where close...
