egr by pass
RE: egr by pass
hey i just did this on a 94 gt motor...took off the egr, made a plate, and disconnected my smog pump. it seems that the smog and egr were hooked up to some sensors under the passenger fender. does anyone know if this will throw an engine code?
RE: egr by pass
it will throw a code but on ebay they sell an piece ot plug into the EGR harness and it will clear the code, pretty much telling the ECU lies that the EGR is opening and closing when it tells it too
RE: egr by pass
what it does is eliminates the recycled fuel from goin to the combustion chamber alowing pure fuel only to be burnt which will result in a small increase but much better for the engine in total .after all egr is just a form a polution control and really don't amount to nothin.
RE: egr by pass
in short term its just added junk to get in the way. by the way not to be rude and switch models but due they make that by-pass plug for the T-bird supercoupes. i need all the room i can get under that hood.
RE: egr by pass
im sure you must know someone some where in a machine shop give them the dimensions of the egr plate or just give them your old egr and they can make you a block off plate, i work in a machine shop myself thats all i did i took it off copied it got a piece of 1/4 in alumplate cutand milled it to size drilled the two holes in itpolished it and i was done...easy fix and cheap
RE: egr by pass
ORIGINAL: Alero99
