87 GT problems after changing thermostat...HELP PLEASE
I changed the thermostat & the little hose that comes off the housing for the thermostat, also flushed the radiator. Ever since then I've had problems, but not constant. It gets worse each time though. Okay, first, I try to use the defrosters/heat & it fogs the windows inside & is very hard to clean off, likethe "fog"just sticks there.Therefore I can't see. Then it starts blowing white stuff out of my heater vents...constantly, as of today.Even when I pulled over because it appeared to be overheating (according to my guage [:S] ) , and shut the car off...the white stuff kept coming out of the vents. It almost looks like smoke, but it's not. When I turn on the blower, it looks like powder blowing everywhere. I am completely stumped & am disabled, therefore on a very limited income. Even if I did have the money, all the shops around here have ripped me off...badly. It also still appeared to be overheating, but my fluid is full, I haven't lost any. It didn't seem to be overheating, but I didn't want to take any chances.
Also...Has anybody ever heard of the heater core being backflushed whenever the cooling system is flushed? Or has anybody ever done this?
Any help would be so greatly appreciated.
Thanks.
RE: 87 GT problems after changing thermostat...HELP PLEASE
here what probly happend when you flushed your systomit ezposed a small hole in your heater core causing the steem after you turn off the car it sucks in air through the hole coasing an air buble in your systom making it look full and cousing it to over heat. you need a new heater core. mine was doing the same thing and once i changed the heater core it stoped. and just to let you know getting to the heater core is a pain in the butt.
ORIGINAL: robs87fox
Just bypass the heater core until you can get it fixed of spend a whole day doing it.
