fox & sn95 front calipers the same??
Just wandering if anyone would be able to help me, doing the 5 lug 4 wheel disc conversion and i was just wandering is my 92 gt calipers are the same as the 95 calipers i have for the conversion..??
RE: fox & sn95 front calipers the same??
sorry mine didnt apply with fiox maybe it will still help
'94-95 V6 & GT: 10.8x1.0" front rotors, 66mm single piston calipers. Rear single piston 38mm Varga caliper, 10" solid rotor
'94-98 Cobra, '95 Cobra R: 13.0x1.1" KVH rotors, 38x38mm dual piston PBR calipers. Rear single piston 38mm Varga Caliper, 11.65" vented rotor
'99+ V6 & GT: 10.8x1.0" front rotors, 44.5x44.5mm dual piston PBR calipers. Rear single piston Varga caliper, 10" solid rotor
'99+ Cobra: 13.0x1.1" Brembo rotors, spec'd 40x40 mm dual piston PBR calipers. Rear single piston 38mm Varga Caliper, 11.65" vented rotor
'00 Bullitt Mustang: Same brakes as 94-98 Cobras (unique red PBR calipers with running horse up front, same varga caliper in rear painted red.) Rear single piston 38mm Varga Caliper, 11.65" vented rotor
'00 Cobra R: 13.0x1.1" Brembo rotors, Brembo 4 piston calipers. 36x40mm pistons. Rear disc the same as the stock '99+ Cobras
