Turn signal don't work, but hazards flash outside and on panel inside. I heard it could be a flasher switch or another switch. Does anyone know what switches I need and where I can get them. I need to fix this b/c this just increases the changes of an accident.
When my blinkers quit working it turned out to be the ignition switch was falling apart under the steering column.
That could be it b/c that white post under steering column that turns on hazards when pulled out is pushed in the up position with a bolt holding it up. If I take off the bolt the white post goes out, then hazards whould be on and I can't pull keys out.
