exhaust
exhaust
im putting an o/r H pipe on my cobra and i was wondering about a catback i found... its an underbody dump with turndowns. Made by flowtech. its basically just 2 pipes going into warlock turbo mufflers and turn down,... wouldnt this be good because there is no pipe going over the axle? plus how do turbo mufflers sound of a 5.0? its pretty cheap so i was wondering what u all thought... also im looking to spend a bit more cash and im looking to hit around a 13 flat... right now im running a 13.7 @ 99.5mph on street tires with a 1.8 60ft and the stock 4 cats with 160k on the car... what should be next?
RE: exhaust
do you guys like your dumps? cause im goign to be getting a better exhaust system with bassani long tubes, there o/r x pipe, but i cant tel if i should get dumps or just a normal cat back.....its more of a drag/car cruise orientated car
Hey man if the dumps are cheap why not, less weight, and better performance
RE: exhaust
o and to hit a 13 flat just get a wet 100 shot and that should be enough to get you there, though you may want to upgrade the tires also as you will have the POTENTIAL of breaking loose
RE: exhaust
lol the potential... i like that... but no i want to stay away from n20... i know a million of you out there like it, and im not going to argue its cheap and eas power, but i want power without a bottle...
RE: exhaust
How much are you looking to spend? The stock Cobra engine is capable of a lot. With tuning, 3.73s, full exhuast and a street tire a guy I know ran his '95 Cobra to a 13.2, so with your gear and a sticky tire you could be close. Otherwise a head/cam swap will get you 12s pretty easy.
junior04
09-28-2015 10:53 AM
09-24-2015 09:18 PM
