What's the part called?
The one on the very back of the transmission that has the hole for the shaft? It appears to be pressed into place. I leak a bit of fluid from there and want to replace it before I put it on the engine and get it back in.
RE: What's the part called?
:eek:you mean the tailshaft seal???
ORIGINAL: mjr46 :eek:you mean the tailshaft seal??? Thanks a lot though, now I know what to say when I go buy a new one!;) |
yeah it easy to do just jack the car up your gonna need a 12mm 12point to get the driveshaft bolts out then pull the shaft out of the tranny, the seal will pop out with a screwdriver or prybar etc then you just tap the new one in place evenly
ORIGINAL: rmodel65 yeah it easy to do just jack the car up your gonna need a 12mm 12point to get the driveshaft bolts out then pull the shaft out of the tranny, the seal will pop out with a screwdriver or prybar etc then you just tap the new one in place evenly |
ok just make sure to lube the seal before you put the d/s in so it wont be dry it will kill it quickly
Just an FYI if you go to a parts store, its called a rear main seal. Theyre like 5 bucks at any auto place.
rear main is the rear seal on the engine for the rear main bearing
| All times are GMT -5. The time now is 11:34 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
