I ran the 85 today!!!!
Old 04-19-2008, 05:44 PM
Hollister Hoodlum
Hollister Hoodlum's Avatar
Default RE: I ran the 85 today!!!!
YAY a video of it on the track!!
wow it ran better than i thought, i want to see some runs with spray eventually.
Really nice run guys. And Pro i'd take your car
Hollister Hoodlum is offline
Old 04-19-2008, 06:44 PM
punisher91279
punisher91279's Avatar
That was awesome, you guys laid more rubber than a high school kid on prom night!
punisher91279 is offline
Old 04-19-2008, 07:12 PM
Shelty
Shelty's Avatar
friggin sweet.
man, pro's car really lifted the nose up, guess that k-member ditched a good amount of weight hah
awesomeness none the less....
I hope to run my car in a month at beaver creek, the day there is the day after the end of finals week... so hopefully I can go, cuz I have to pack up all my crap, etc etc....
Shelty is offline
Old 04-19-2008, 07:14 PM
jtmustang
jtmustang's Avatar
nice guys and both of your cars look good and it looked like u did pull a little tire off the ground pro
and this makes me wanna get mine to the track but i said the same would be nice for a while and i got 200 miles on the motor below and it is hard not gettin all in it but it feels way faster than stock
jtmustang is offline
Old 04-19-2008, 08:01 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: jtmustang
And I had 120 on my motor!!! if it's gonna let go no sense waiting until it gets 3000 miles on it cuase it'll do it then or now so go or blow!!!
mjr46 is offline
Old 04-19-2008, 08:06 PM
mjr46
mjr46's Avatar
ORIGINAL: OnyxCobra
Nice runs guys. What's the top end on your 347? I really want one now
Bernie your car looks so, well, Pro Looks like u mighta bogged a little that run...
AFR 185's and a comp cam xe 282 hr .565/.574 ...1.6 comp pro magnum roller rockers and an rpm air gap intake with a 650 double pumper carb 1 5/8 lt's......some say I should be using a single plane victor series....but got a special paint job and stock hood= no more clearance for the single plane unless I ditch the NOS plate....but I think it performed quite well considering it is the same build and all the same parts reused/transfered over from the 306, The results exceeded my expectations and if I wanted more I still have the 100 SHOT availible
mjr46 is offline
Old 04-19-2008, 08:21 PM
67mustang302
67mustang302's Avatar
Nice. That lil 347 makes good power, and it doesn't use a huge h/c/i setup to do it. What were your 60's?
67mustang302 is offline
Old 04-19-2008, 08:26 PM
mjr46
mjr46's Avatar
ORIGINAL: 67mustang302
I'm actually quite suprised at the power it makes as the afr heads are out of the box deals..now I did open up the spring pockets to accept larger springs ..but no extra port work or gasket matching and no huge intake either.....and not even a custom cam just a good ole OTS cam...make you wonder if I'd done all that if it'd of gonne even more...and there is still room for improvement as my 60 fts sucked...first run spun bad 1.96[:'(]and the second run I didn't launch as hard and let some more air out of the tires and pulled a 1.70 60 ft...better but still could improve
mjr46 is offline
Old 04-19-2008, 08:39 PM
67mustang302
I'm a firm believer in not needing big parts to make big power, only the right parts. And AFR's seem to do really well right out of the box. That XE282 is the biggest HR cam they make for the street 302's isn't it? I wonder how the 347 would run with one of their newer XFI stroker cams designed for 347's. Or a nice custom solid roller from CI.
Old 04-19-2008, 08:45 PM
FuzzyDiceRule
FuzzyDiceRule's Avatar
dayum, makes me wanna head to the track
too bad mines a 14 second car
and the only good track near me is 1/8th
FuzzyDiceRule is offline
Quick Reply: I ran the 85 today!!!!
