Installed 4.10 gears! - Page 2 - MustangForums.com
Old 04-23-2008, 05:16 PM
OneFine89Mustang
Default RE: Installed 4.10 gears!
they need like 500 miles to break in..after that if they are still whinning i would take it back then
OneFine89Mustang is offline
Old 04-25-2008, 11:15 PM
nhrichard
My experience with FRPP gears is that the gears I got were finished differently & looked different than usual. Could not get a proper "pattern" across the gear faces. After assembly the gears whined like crazy. Upon removal & comparison to the old FRPP gears it was obvious that they were different, with different numbers etched onto the rear facing of the gears.Ford changed gear manufacturers & this was confirmed after calling FRPP. FRPP subcontracted the gears to Motive. Richmond gears looks like an alternative.
For my Mach1, I tossed the Motive gears & was able to use 3:73 Ford Ranger gears without whining. Still running quiet.
nhrichard is offline
Old 04-26-2008, 01:43 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: camaroeater
ORIGINAL: OnyxCobra
If the gears are whining they were installed wrong, get it back to them asap.
Two shops have quoted me 8-850.00 for gear install. I said thats alot and they said if you get in done cheap, the gears will whine.
..find a different shop!!!! for 850 beans you could have the whole rear rebuilt!!!
mjr46 is offline
Old 04-26-2008, 01:47 AM
mjr46
mjr46's Avatar
ORIGINAL: lxman1
My 3.55's are a little noisy. Always have been. They guy that did mine worked at a Ford dealership as the drivetrain guy. He set mine @ .012 so that under hard acceleration, they would be in the sweet spot.
say whaaaaaaaaaaa???? spec is .008 to .012 and rule is set as close to .008 as you can cause as it wears in the spec will fall toward higher side..cause if you set at .012 when it's all said and done it'll end up around .015 or higher and that's excessive backlash and clunks will be evident expecially on an auto car and or noise prevalant.....sweet spot is .008 and when it wears in .010 to .011 are the sweet spots
mjr46 is offline
Granatelli Sales
The New S550 2015-2020 Mustang
21
04-27-2017 02:33 PM
musnicki
09-23-2015 08:11 AM
TimeLord101
09-04-2015 10:27 AM
cbird1177711
09-03-2015 09:43 PM
09-03-2015 08:14 PM
Quick Reply: Installed 4.10 gears!
Featured Sponsors
