Installed 4.10 gears! - MustangForums.com
Old 04-22-2008, 10:53 PM
94gtcobra
Default Installed 4.10 gears!
They just installed my 4.10 ring and pinion, but there's whining noise, is it because they are new and new to break in. Or is it because they are installed wrong. Also what is the cheapest calibrator for the speedometer. [/align]
94gtcobra is offline
Old 04-22-2008, 10:54 PM
OnyxCobra
OnyxCobra's Avatar
Default RE: Installed 4.10 gears!
If the gears are whining they were installed wrong, get it back to them asap.
OnyxCobra is offline
Old 04-22-2008, 10:58 PM
94gtcobra
So if there is whining, they are installed wrong. I installed Motive Gears.
Old 04-22-2008, 11:02 PM
WhiteWindsor
It depends on how much whining is there. The lash setting is around .007-.012. If they set it to the tight side the whining could go away in a bit. With the gear installs i've done i always set them a little tight and eventually the noise go's away. Just keep in touch with the shop and let them know whats going on so they'll know. And if the noise does not go away take them back. Dont forget to change the fluid after 50-100 miles and make sure there are no shavings.
WhiteWindsor is offline
Old 04-22-2008, 11:06 PM
94gtcobra
its not extremly loud but you could hear it, its only when im in 4 th gear in Over Drive. Its and AODE.
Old 04-23-2008, 02:17 AM
lxman1
My 3.55's are a little noisy. Always have been. They guy that did mine worked at a Ford dealership as the drivetrain guy. He set mine @ .012 so that under hard acceleration, they would be in the sweet spot.
lxman1 is offline
Old 04-23-2008, 10:56 AM
camaroeater
camaroeater's Avatar
ORIGINAL: OnyxCobra
Two shops have quoted me 8-850.00 for gear install. I said thats alot and they said if you get in done cheap, the gears will whine.
camaroeater is offline
Old 04-23-2008, 11:09 AM
OneFastEclipse
If you buy cheap gears they will whine. I'm not sure about the motive gears, but cheaper gears such as ones from Summit Racing will whine no matter what you do. I prefer Ford Racing brand gears.
OneFastEclipse is offline
Old 04-23-2008, 11:54 AM
94gtcobra
I guess it will get better after time, i have only had them for 2 days.
Old 04-23-2008, 01:58 PM
PJB
Mine whine at certain speeds but I think its because they were used gears and the guy that installed them screwed them up a bit.
Check 50 Resto for the speedometer correction gear.
PJB is offline
Quick Reply: Installed 4.10 gears!
Featured Sponsors
