Questions on a 94 GT i just bought
Old 03-11-2008, 01:35 PM
Tetsuo
Tetsuo's Avatar
Default Questions on a 94 GT i just bought
Yesterday i just picked up a 94 GT. I have a couple question's about it and i sure you guys can help me out.
This has disk brakes in the rear and drilled in the front....Is disk brakes in the rear and drilled in front come stock on a 94 GT?
I have a slight low ticking sound coming from the motorcan this be in the block? If not what else can it posibly be? I got a new complete shortblock that came with the car so if that is the problem i would just convert old to the new block.
Thank for the help guys.
Tetsuo is offline
Old 03-11-2008, 01:46 PM
94Yellow50
94Yellow50's Avatar
Default RE: Questions on a 94 GT i just bought
stock the brakes were disc all the way around...in ur case someone just upgraded the fronts to drilled rotors...either didnt have enuf money to do all four corners or the backs werent worn yet so he left them. as for the "slight tick"..that could be numerous things..try to figure out where its coming from n advice will be easier to give.
94Yellow50 is offline
Old 03-11-2008, 02:49 PM
98MustangGT46
98MustangGT46's Avatar
You know there could be a reason he gave you shortblock with the car cough*tick*cough.
Definetly find out were the tick is coming from and what time of tick it is. The more you found out the better we can help you.
98MustangGT46 is offline
Old 03-11-2008, 05:42 PM
Tetsuo
Tetsuo's Avatar
ORIGINAL: 89MustangGT50
Yup me and my buddy which is a big Stang man is gonna look at it tomarrow. We belive it might be a loose header.
I will let you guys know what we find.
Thanks.
Tetsuo is offline
Old 04-19-2008, 11:44 AM
Tetsuo
Tetsuo's Avatar
Update:
The ticking sound is coming from the driver side near the head. We put new header bolts and tighten them up and replaced the lifters and installed Crane 1.7 rockers. We also did a oil change with synthetic and adjusted the timing.
The "ticking" sound still exist.
My uncle said it could be a bent pushrod but they seemed to look fine.
Does anyone have any ideas?
Tetsuo is offline
Old 04-25-2008, 05:25 PM
Tetsuo
Tetsuo's Avatar
This is a Mustang forum and i cant get no help??
Tetsuo is offline
Old 04-25-2008, 05:39 PM
stang8689
stang8689's Avatar
Don't think its a push rod, hoe loud is the ticking
stang8689 is offline
Old 04-25-2008, 07:31 PM
red95gtconvert
red95gtconvert's Avatar
Could be a lifter sticking.
red95gtconvert is offline
raleigh05GTO
09-04-2015 07:09 AM
Luke9222
09-04-2015 06:46 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
09-02-2015 08:40 PM
Quick Reply: Questions on a 94 GT i just bought
