you hooked llike crazy, whats your suspension set up?
I have METCO uppers/lowers. 4 cyl springs and lakewood 90/10's up front. Rear has 50/50 and moroso drag springs. It can hook better with better tires i think. I'm using bfg DR's now. My best short time is 1.72.. I'm thinking i should have better times because i'm trapping at 116-117 mph. The car has plenty of top end but not enough low end grunt. I have a nitrous grind but i'm not using nitrous, so that is hurtin a little bit. I'm trying to make up for the low end by dumping the clutch at 5500. Next time i'll try leaving at 6500. Hopefully the spec stage 3 clutch will last awhile. It's been doing great since i've had it which has been 1 year. I'm still spinning in second and a bit into third. I'll be around 11.40 before the season is over, i hope.
