NMRA Pure Street Buildup Pics (Update)
#24
Thanks, just a few more odds and ends and Ill be ready. Too bad nothing on that list is cheaper than $500.......
REAR END
33-Spline Axles with 5/8 studs
Ring gear cut, polished, and blue'd
Ceramic wheel bearings
Fuel Cell (BBRC 5 gallon stock replacement)
Headers Coated (Jet-Hot)
Cam Installed
Pushrods
Custom 650 Carb ($1200)
Finish paying for the Custom AOD (Owe about $1700)
Driveshaft
Then Installing it all and firing it up
REAR END
Cam Installed
Pushrods
Driveshaft
#26
They are Trick Flow TW heads ported by Ron @ Fox Lake. Im using Harland Sharps shaft mounted rockers that have a custom Diamond Cut to cut some weight off them. And the cam is a hydrolic custom grind to fit the rules of Pure Street (.500 lift max)
