Axle damper Shock help!!!
RE: Axle damper Shock help!!!
Most people here willtell you to get a set of lower control arms and junk the quad shocks. I got a set of uppers/lowers and still run the quads. I replaced them with stock ones. the shocks from a 94-04 will work. You can get them from a Ford dealer.
Your best bet would be to buy some lower control arms and remove the quad shocks. If you don't want to do that then as many people do you can flip the quad shock around to help clear the larger tire.
oh yeah http://www.bilstein.com/
makes them new if you want
summit sells them, also
steeda.com sells them as seen below
B36-2149 HO
85-04* Bilstein Quad Shock (each) $84.00
Product Details
Quad Shocks control axle "wind up" to eliminate wheel hop and increase traction. Replace your worn out quad shocks with these high quality replacements.
*NOTES: Do not fit 1999-2002 Cobra.
B36-2149 HO: 86-04 Quad Shocks
An upgraded “Mono Tube†quad shock, fits all Mustangs with factory quad shocks, and most importantly will fit with ALL aftermarket stock location rear shocks.
B36-2149 HO
Product Details
KingRando
10-02-2015 08:06 AM
09-24-2015 09:18 PM
