just came from da track 2 day
i wanted a baseline from my cay , here are the mods so far ;
equal length shorties
h-pipe with flow masters dumped
msd coil
c.a.i (BBK)
A.C DELETE
SMOG DELETE
STOCK GEAR
STOCK A.O.D.
MY BEST TIME AT THE 1320 WAS AS FOLLOW:
REACT-.0780
60FT-2.26
1/8 ET-9.7099
1/8 MPH-72.35
1,000FT ET-12.6381
1/4 ET-15.031
NOW I WANT TO KNOW HOW I STACK UP WITH A SN 95 STOCK AUTOMATIC MUSTANG AND WHAT DID A STOCK MUSTANG PERFORMANCE #'S ARE FOR THE SAME CAR AS MINE. ANY INFO IS APPRECIATED
msd coil
c.a.i (BBK)
A.C DELETE
SMOG DELETE
STOCK GEAR
STOCK A.O.D.
REACT-.0780
60FT-2.26
1/8 ET-9.7099
1/8 MPH-72.35
1,000FT ET-12.6381
1/4 ET-15.031
RE: just came from da track 2 day
That's not a bad time for a stock auto. I used to run 14.2 with a stock 91, only difference is mine was a manual. The stock autos on our cars suck. A stall would help.
I HAVE BOUGHT A FRPP RING AND PINION AND A TRACK LOCK REBIULD KIT,DA GEARS ARE 4.10 BUT II WANT A STALL THAT WILL COMPLIMENT THOSE GEARS ,AND IF IT MAKE A DIFFERENCE IM GONNA SPRAY IT WITH 100 SHOT , WHAT DO YOU GUYS SUGGEST?????????
[sm=helpout.gif]
[sm=helpout.gif]
Install your gears. Cant give you much info about a stall, i've never bought one. Will a 100 shot improve your times? Doe's a wild bear **** in the woods? Suspension will help you a ton. SCF's and u/l control arms is where i would start.
WOOPS I THOUGT NOBODY WONT AWNSER , BUT ANY WAYS WHAT TIMES WOULD YOU EXPECt with the future mods i kinda got da reacton time downpacked that was whith no wheel spin at all . that track was sticky today
I'm sure someone with an auto will chime in and give you real world info. But guessing i would say that with100 shot and gears you should knock an easy second off. What tires were you using when you ran it.
