Best Parts for Built 5.0
#23
RE: Best Parts for Built 5.0
yeah how much does it get driven and how long has it been runnin cause any one knows that is a ticking time bomb , why do that do it right aftermarket block and good tune and turn up the boost and not worry about it to an extent.
#24
ORIGINAL: kweb288
start from the rear and build forward thats what i am doing. (o and do suspension also before you touch your engine)
I started with a built 8.8, then went to a TKO 600, and full suspension (almost done) so that whne i started building the engine up i would not have to worry about breaking stuff even though i know something will probably break, it will be less likely to happen
but a budget would definatley help with getting you started on pieces....dart block???/
Kyle
Kyle
#27
For the motor, start with some Trickflow Twisted Wedge Heads, Ported GT40 intake, and a custom cam. That setup will get you 290-300rwhp with a good tune. Once you get your Kenny Bell, you'll already have your GT40 lower that's ported so you'll be all set with a nice lower intake to bolt the blower on. Once you have your Kenny Bell, you could easily see high 450-500rwhp through that setup. Keep in mind, you need all the supporting mods such as injectors, fuel pump, MAS, exhaust, intake, chip, etc. Starting with the HCI I mentioned above will keep you satisfied until you are ready to jump into the bigger power.
#29
ORIGINAL: Gary H
What else is done to the car? Gears, SFC's and control arms will make the car quicker.
#30
ORIGINAL: OneFastEclipse
