Wheel Hop
Wheel Hop
whenever i try to spin the tires of dry pavement the rear of the car starts hopin...at first i tought it was the bad tires i had but when i replaced them it didnt fix the problem...a friend of mine said that if u have crappy shocks that can happen...have any of you expeirenced this? is the shock story true? if so how'd u fix it and wut shocks would correct it
RE: Wheel Hop
iight cuz i have ford racing springs and im ordering KYB gas adjustable shocks so hopefully when i get some new control arms it'll fix it
its aggrabvating u go to show off and all u get is hop and no smoke
RE: Wheel Hop
the quad shock set up is not the cause of wheel hop.. incorrect pinion agle can cause such but most likely the cause is the control arms.. my 92 did this and I just installed a set of control arms and prob solved
