balancing internaly
balancing internaly
I am about to order a stroker kit for a 347 i need to know how to determine what to balance my crankshaft to, its a 90 stang gt it appears to have an 1987 crank in it im not sure but the numbers on the crank r e7ae-aa. Is their a way to determine what to balance it to? The rods are 90 model? Thanks
RE: balancing internaly
Its 50oz external balance now, cast crank strokers will balance to 28oz external, all windsors (69-97) and 302's up until mid year 1981 were 28oz external balance. You will be balancing to 28oz on cast crank strokers, unless you have money falling out of your pocket to internally balance the crank as the counterweights are made to be close to 28oz. Internally balancing a cast stroker crank will require mallory metal, if the crank is a forged unit, depending on which one it may go internal without mallory metal. So if its a cast crank balance to 28oz external which will mean you have to buy a new flywheel/flexplate and harmonic balancer, 28oz external pieces. Yes you can balance a cast stroker crank to 50oz if you want to be cheap and reuse your current flywheel/flexplate and harmonic balancer but its highly advisable NOT to. So in the end, balance the rotating assembly to 28oz and buy new flywheel and harmonic balancer.
jessicarabbit
09-25-2015 12:41 PM
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
Urambo Tauro
08-27-2015 10:53 AM
