Electric fan relay
Electric fan relay
My fan itself tested out fine but still does not come on when the heat gets up. I assume it is a bad fan relay since the ECT was replaced and the fuse replaced. Does anyone know exactly where this relay is and what it looks like?
RE: Electric fan relay
Yeah, sorry folks. 1995 GT, stock (other than exhaust, K&N). Read posts that it may be with or near the CCRM but nothing confirmed. There is a fuse but no relay in the under hood fuses. Replaced that one, no difference though.
Just to add a note... I found where I had this same problem about 5 years ago and the place that fixed it replaced "A/C high Pressure Switch" and "Fan Control Relays Assy". I assume that the 2nd item is referring to the CCRM assembly? Does anyone know what the "A/C High Pressure switch" looks like and where it is located? I found something that said it was near the passenger strut tower but can't seem to pinpoint anything near that location. THANKS!
the a/c hiigh pressure switch will not come into play with normal fan operation when a/c is not in use...if fan won't come on with a/c off and temp creeping toward hot range.. I'd look for a different prob like ccrm module/relay
Weird, now the fan IS coming on. It was running a bit cooler but just took the car back out and it is riding about 1/2 to 3/4ths temp range.....too hot still. Not overheating but it is running too hot. I can see the fan is on and radiator is full. Any ideas on why this may still be running on the hot side?
Both waterpump and thermostat changed recently. As I look a bit further it appears that the fan may be coming on intermittently (and not always when it should). The car was over half way on the gauge and I popped the hood and the fan was not on. In this range it should have been. I am assuming it could be a fan connector going south (seems it started working when I WD-40'ed the connector and tapped on it) OR the CCRM might be the issue. Can I change out the connector on the fan or do I have to replace the whole harness? Not sure there is enough extra wire to cut and splice. Has anyone had to replace the fan connector?
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
