MAF or Speed density
Ok, so I started a project a couple years ago to take a junk yard car that had no engine or trans to a 5 speed gt. Im in the process of wiring up the engine and I needed some info on mass air and speed density. Does one have any benefits over the other and do they use the same computer or what? What are the differences?
RE: MAF or Speed density
when i started converting mine i had to swap ECU's and i think the three u can use are a9l a9t and a9p...id go wit maf bro...speed density is very limited in what you can do from my research
Just a little info on the engine, if it helps. The engine I'm wiring up is bored 60 over, stock upper (except for big valves in heads), b303 cam, crank ground .10, resized rods, 150lph fuel pump and 19lb injectors for now. I'm going to do a bit more to it later.
jwog666
12-27-2021 08:09 PM
BeatnikFink
10-01-2015 08:00 PM
musnicki
09-23-2015 07:11 AM
