What injectors for my 347?
Hey im putting my NA 347 together AGAIN!! but im ditching the HUGE FRPP 42lb's and my Trickflow track heat intake. Im going to run the Victor 5.0 or a Spyder II intake and im goin to run some 30lb or 36lb injectors. I'm also ditching my 85mm C&L and running a Pro-m or that crazy new anderson motorsports MASS Air meter. Im still running the out of the box AFR 185cc heads so tell me what you guys think i should run for the intake/injectors/Mass Air. I was thinking Spyder II, 36LB injectors and the Pro M, I know the Spyder II will kill my bottom end but im running a C4 with a Brake and it will be launching around 3200-3800 RPM Thanks Alot
RE: What injectors for my 347?
cheapest i could find them, i got mine a few months ago they were 189.99, looks like the price went up since then...
http://www.buyfordracing.com/shop/pr..._id=624cPath=9
go for which ever intake flows better at higher rpm's if you plan on launching that high then.
and the type of intake shouldn't matter when choosing injector size.
i was happy with my holley/frpp30#/pmas maf setup.
