306 turbo build!
RE: 306 turbo build!
i have a edelbrock rpm 2 intake that im going to part out as soon as i get my efi spyder.
let me know if you are interested. the holly and eddy intake make pretty much the same power.
no more than .030 on the bore. why not stroke it to a 331 and it would only take a couple psi and the block wont split. a 347 and the same psi would put the power up there, and i would be concerned about cracking.
ORIGINAL: Jasperstang308
a 306 with a h/c/i and a turbo is more than enough for the stock block
So im hoping for about 400 -450hp on the pavement with a budget of roughly 5-6K.. going to be running M/t et streets 275/40/17.. hope fully that should be ok if i launch it in low boost..anyways this is going to be a long project-
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
