What intake for my setup???
Old 07-03-2008, 11:00 AM
93reefblue347AFR
93reefblue347AFR's Avatar
Default What intake for my setup???
I have a Track Heat intake as of now but you would ahve to think its choke'n my 347 some what, im goin to run a 80 or 90 mm TB and the ports on the intake ar smaller than the intake runners on my AFR 185's and i have a big cam. I got down to about 3 intakes Vicot 5.0, Spyder II, or maybe even one of those 4B throttle bodys that go on a carb style intake. I dont know anything about the 4B throttle bodys so if you guys can give me some info on them pros and cons. I would think that would only really perform in high RPM but i dont know.
93reefblue347AFR is offline
Old 07-03-2008, 11:10 AM
Mustangkiler
Mustangkiler's Avatar
Default RE: What intake for my setup???
Id go for the victor jr its going to be the easiest to install for all the throttle linkage and best chance of the three of not losing all your low end torque.
Mustangkiler is offline
Old 07-03-2008, 02:44 PM
jtmustang
jtmustang's Avatar
good lookin car man..
what does it run now or how much horses? looks pretty healthy right now...
jtmustang is offline
Old 07-03-2008, 05:21 PM
93reefblue347AFR
Jtmustang last year when it was running i had a stock AOD with a 3200 stall converter in it and it was on the breaking point at all times, it didnt even have reverse and the converter would not stall at all, if i foot breaked it i couldnt get it pased 1200 rpm and the custom cam i had made for it worked from 3600-6800 so my 60 foot was really bad and for some stupid reasin i was running 42# injectors and it was running really really rich. but it ran 13.60 but the MPH was like 110 and i had to feather the gas alot to get the trans to shift . when it opend up after the first 1/4 of the track it was running strongbut after i get my C4 with a trans brake and my 30lb injectors it should run high 10's low 11's
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
fastbackford351
10-01-2015 12:24 PM
guitarman376
09-30-2015 05:54 PM
Drastang
09-29-2015 03:31 PM
Quick Reply: What intake for my setup???
